it keep breaking in the same place. im not sure if its the positive or ground, but its where the wire goes over the valve cover and screws underneith a nut on the front of the alt. twice the external o-ring that is tightened down snapped. so i got a heavyduty pack of monstercable o-rings... then it pulled the entire connector out from inside the alt.
so then i added about 6" of cable to give it some slack... and again today it ripped out again. wtf is going on?? my engine has a solid front mount... so it cant be moving back and forth causing the alt. to yank the cable out. what is it????
