blinker/Flasher Relay Help needed!
    Ok guys, I was on the highway on Sunday afternoon just cruising, changing lanes, etc. I always(mostly) use my blinkers when chaning lanes, they were working fine while on the highway but after I exited I try to put my signal for a left turn but there was no green arrow blinking on the dash and no ticking sound that it normally makes when blinker. This seemed strange so i tried to put on the right signal and I got the same response(no blink, no sound). All other icons on the dash works fines. I then proceeded to put on my hazards but to my confusion they worked fine. When I put the hazards on , both green arrows blink on the dash and the associated sound also works like normal. I check the four corner of my car to make sure that they were blinking outside while the hazard were on and they were. So hazard works fine but the signals done work individually. My questions are........is there a fuse just for the blinkers? Could this be a Flasher relay issue? If so, where is the flasher relay located?
    I was told that it could be the blinker lever thingy that went ape shit and i need to replace it. Will be greatful for all info offered
    1993 Accord LX - Sold
    93 BMW 525it - SOLD
    92 Accord EX Sedan - SOLD
    2000 Accord Coupe - Traded-In
    2003 Accord V6 6spd Coupe - Sold
    2001 Honda Civic Ex - SOLD
    2013 Chevy Traverse LTZ - Kid hauler
    2003 Acura Tl 3.2 - Daily Commuter
    Sounds like it may be the Multifunction switch for the headlights/turn signals.
    Napa Part # DL6010
      Napa Part # DL6010
      Thanks Matt, does it come with the lever like that because I put the # on there site and it shows a different pic or sorts.
      93 BMW 525it - SOLD
        That is the # that any shop would use/lookup for that problem. I used to do that with the shop I worked at. I use a program only available to shops.
          Napa Part # DL6010
          x2
            This is the image on napa's website
            it doesnt look like yours but maybe its just the back part.
            93 BMW 525it - SOLD
              i agree too. it's your switch stalk.
              1cor10:31
              - 92 LX coupe
              - 96 EX wagon (sold)
                Could just be the turn signal flasher. It is seperate from the hazard flashers. If you are getting solid green arrows on the dash the switch is more than likely good. Check the turn signal flasher before you spend money on a switch.
                The 90 Accord 4DR Sedan my son and I are building.
                  I'm not getting solid green or any green when i use my flashers. The switch stalk thingy does work at all.
                  93 BMW 525it - SOLD
                    just top off the blinker fluid and you should be good, they stop working if it gets too low...
                      i forgot about that...
                        yeah , i should try that but anyways. I replaced that turn signal switch and it still dont work. I tried 3 different ones from the junkyard and it still dont work I even tested and changed fuses to see it that works but still dont......anymore ideas guys...I'm stumped!
                        93 BMW 525it - SOLD
                          bump
                          93 BMW 525it - SOLD
                            Fuck Man, Am I The Only Guy That Ever Had This Problem?? Come On Guys, Someoen Help A Brother Out.
                            93 BMW 525it - SOLD
                              ahh hmm.. try replacing the hazard button. yours might be faulty. if you notice: unplugging the hazard button causes the signals to stop working entirely. maybe it just went out
