OK, I just changed my TB again today and cleared all CEL codes...but my car is still surging at low RPMs! These are the symptoms...
-When I first start the car it revs to like 2.5K and takes long to settle.
-When I get the car moving it surges a bit
-If I'm coasting under 1500RPM and I touch the gas, the car surges to 1500RPM and will not stop till it reaches there...then it goes back to idle
I had this problem before when I did my mounts, as I had to remove the TB...I plugged a vacuum line that was loose and it behaved funny, so I unplugged it and it went back to normal. Problem is, after doing my H23 plenum swap, I can't remember which line it was...all I remember is that it runs left to right from around the MAP sensor, and it doesn't connect to anything in my car. I'm flipping out trying to figure out what it is...if anyone with an F22A6 can post a pic of their vacuum lines I'd really appreciate it.
