Can the H22 leak coolant from the timing belt cover? it looks like thats where mine is leaking from. any ideas?
Coolant leak
^^Yah man, it sounds like your water pump is kaput sure as shit.
The water pump is located right there, under the plastic lower timing belt cover.
Good luck, this is a tough job to get too.
...when did you last do your timing belt service?
If never(im assuming you have a JDM h22), you might as well go ahead and change the timing belt, belts, water pump, seals etc.etc.
1990 Accord Lx F22a1(Daily)
SOLD - will be missed
