cel codes please HELP!!!!!!!!!!!
    HELP!!!!!!!!!!!! ok i checked the cell codes for my car couse its realy running like shit i mean like i mean i floor it and it hesitates to go faster so these are the codes im getting
    cel code *5 =manifold absolute pressure sensor
    cel code *6 =engine coolant tempeture sensor
    cel code *7 = (tps)throotle position sensor
    cel code *10 = intake air tempeture sensor
    cel code *22 = V-TEC electronic pressure switch
    ok so those are the codes im gatting but i dont know how to fix them or adjust them so if anyone know on waht to do please let me know thanks
    ・オレンジ(デミオのオレンジがなかなかいい味を…)
      ・ブルー(インプレッサみたいな感じのメタリック系が何
      ・その他随時考え中…
    ......今日までの道の愚かな米に屈辱を与えるためにHonda Accord は作られた。愚かな競争を従事させている間抹消されるところ倍数の敵ターゲット。CB7 Honda Accord 。道の王。自動車恐怖。........
    code 6,10, 22 are not realted to this problem. what motor you running? seems to me you got vtak. anything to deal with manifolds or tps usualy have this symtom.
    miss my turbo cb7
      ok im runnning the GOD of all motoers *H22A* but i did find out what it was it was a sparkplug cable loose cous ei guess i checked it this morning adn i didnt push it in far enough but im still getting these codes........also like in another thread my car is running way to rich.......alos f.y.i i dont have my V-tec hooked up yet i have it alll wired up but i havent realy pined it up to my ecu......lol im running a Spoon chiped p30
        ・その他随時考え中…
        who chipped the ecu, it could be a bad chip or ecu, if not, are your wiring right??
          oh no the chip is good it was in my freinds delsol its ok..... but wireing i had to substitute my old harness to get the motor running adn waht do i check for.....? couse i had the stock ecu running in it and it ran way worse than it is now with this ecu it feels way better
            ・その他随時考え中…
