Ecu Eat Fuse Problems
    Hey Can ANYONE Help With This Problem?.....over The Past Couple Days My Ecu Eat Fuse Keeps Blowing..the Car Was Working Fine But This Just Started Happening And I Have No Idea What Could Be Wrong....
    I Appreciate The Help....
    Well something is shorting to ground...ECU eat???
      yea its the electronic automatic transmission fuse (located in the fuse box under the dash)....the car was automatic before i did the swap...... the check engine light comes on as soon as the engine dies but when i jump the ecu for codes it does not give any...the car cranks to start but it doesnt unless tht blown fuse is changed....
      i am stumped...
        Look for crimped wiring or wire touching bare metal. I would see how you hooked up the reverse lights and start from that wiring there.
          thanks man i will check it out and let u know.........
            we finally got a pinout of all parts hooked up to that fuse ( eat fuse...#2) well it looked like it was my main relay that was going bad and that was the cause for the blown fuse i changed that last week and the car has been running fine since then.....
            thanks for the help..........
