Okay, I have searched thru this site for the answer I am looking for, and found one single thread on this, but it seemed to have been hijacked.
This is for a 1993 Accord with the F22A1.
So I'm going to ask the following question:
How difficult is it to change out the cam seal, balance shaft seal, and cam seal? I spent about 2 hours tonight poking around the engine area of the car trying to figure out where crap comes off. I understand that I need to:
-take off the belts
-take off the crank pulley
-take off the top and bottom timing covers
-remove timing and balance shaft belts
-carefully remove seals
-sloob up the new seals and install
-replace timing and balance shaft belts
-replace timing covers
-replace belts
BUT:
1-Does the engine need to be at TDC to do this?
2-How the F are the belts loosened? I see the adjuster bolts and the retaining bolts for the alternator and ac compressor, but they don't move after loosening all the bolts; is there a way to get these loosened to be able to move to get the belts off?
3-Is it necessary to get something to keep the engine from turning/rotating while taking off the crank pulley bolt?
4-Is it necessary to remove the engine mount to access the timing belt covers/timing belt?
Finally:
5 Would it be better to have the vehicle towed to a shop to have the seals replaced, (its not drivable (well it is drivable, but very risky), as it leaks about 1/2 quart/min from the timing cover) or should I undertake this in-depth repair? I have little experience in this field of car repair and I feel that I may be getting in way over my head.
Suggestions? Comments?..... Since its in my in-laws' garage on ramps, I need to get this done in a reasonable timeframe, and it cannot be sitting there for more than a week.
Help!!!
-take off the belts
-replace belts
BUT:
Finally:
Help!!!
