Check engine light and lugging
    I have a 93 cb with a jdm h22 stock p13 ecu. i hvae a check engine light but it doesnt come on untill after the engine is started so when i try to pull the code it doesnt work. no blinking. any suggestioins?
    next problem is when i step on it, it wont go. it feels like a stock f22. and when i step on it around 3-4500 rpm power drops out and comes right back. another thing is it only lugs and acts *** when the engine is warm. if its cold when i first drive it has good response and vtec pulss hard. i checked the spark plugs and it looks like it's running lean, the spark plugs where pretty white. would a engine thats running lean do that? would a fuel pressure regulator solve my problems? or help
    Your not supposed to start the car to jump codes just in the on position. The CEL should flash. If not then you prob rewired something or did something wrong.
      i kno, but there is no cell when just the ignitions on. the cell doesnt come up till after the car starts. should i just trace the ecu wiring and check for continuity as well?
