I'm gona clean my manifold, throttle body, plenum, egr port, of my 91 Se CB7 .. But, What it's the better cleaner carbureator cleaner, gasoline, help, really want clean the car. Tnx
How to clean
i use degreaser and a pressure washer. no sweat.
inside a better cleaner would be throttle body cleaner with a rag.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i spray willingly.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
throttle body cleaning
best bet is to remove the throttle body from the manifold. just remember were the vaccume lines were and unplug the sensor. any type of cleaner degreaser will work but i use carb cleaner it worked well. also use a toothbrush cause its easy to get to small areas. clean all over and on the plate and spring release for the plate. after ,carefully clean at the opening of the manifold. when don dry off well and install. good luck dogg.
