h22 oil problem
    h22 oil problem
    ok, whenever its raining out and i park my car within about 5 seconds there is a small spot of oil on the ground. i cannot see it dripping when i look under but its there within like seconds. the oil drain plug does not leak for what i can see. wherelse can i check or where else would it leak from?
    1990 h22 accord ex-r
    You sure its not from the car before you. Hows your oil level. I would get under the car on a dry day and see if anything is leaking underneath.
      im sure its mine
        Well best way is to get the car on jacks or something and look underneath to see where its wet and such.
          ya. the bottom end of the motor is messed. i have another bottom end to put in soon. but i dont want oil leaking like this
            Check the oil cooler between the oil filter and the block. The block side O-Ring is often neglected...
            Originally posted by Junior Smurff
              seems to drip alot. like when im rolling slowly there is dots following the car.
              seems to only be when its running
                Clean underneath have the car up on jack stands turn on the car put it in first get it kidna started and see if you can find where its comin from.
                  I wonder if you have a more progessed leak than I do, as mine does it in smaller amounts and rarely in the same manner.
                  I was thinking it is my oil pressure sender, but you mentioning there is a seal by the oil filter gets me thinking too....
