very high idle
    very high idle
    i took the throttle body off and cleaned it and now im idle at 4500 rmp!!!! what is goin on with this thing. i plugged everything back in but i dunno what its doing now help!!!!
    I like Hummers to... Especially in the morning...
    4x4 Connection.
    turn the idle screw clockwise till the idle comes down..
    red circle is were its located..
    Praise The Lowered...
      Check the accelerator cable, maybe needs more deflection.
      Razer.-
      Rev rev rev
        the trans cable is hanging. i have the screw in all the way. so tomorrow im gonna play with the cable and see if it fixes it
        4x4 Connection.
          high idle
          Check idle screw and acc cable. make sure vaccume lines are good
          and tps sensor pluged, but most likely its ur idle screw.
