Brakes
    Brakes
    Does any one no where to find new backing plates (tin metal shields on the back of the pads) for fronts pads?
    Every time i go over a bump, they sound really bad because you can hear them hit or rattle.
    JD'S 91 Honda Accord. Nothing even compares to a Honda.
    NO NOS, JUST BALLS!!!
    junkyard should have them,are you talking about the tin shield?if so go to a junkyard.good luck.
      Re: Brakes
      Check your front end because pads don't rattle like that. The caplifer always keeps them snug. The shims you are talking about is to reduce vibrations in the pad while stoping that produce squels.
      If you have a rattle it's not the lack of shims that's causing it.
        This started to happen when i chaged my front rotors,bearing and i had to change my pads too but unfurtunately my dad threw the old brakes before i took off the shields. Old brakes didnt rattle i know for sure its because of the shileds. I dont hear the brakes rattle when i step on the brakes. If any one knows where to get new,brand new not junkyard, ones i would definetly apprechiated.
          so ur saying that u dont have the backing plates? well if thats the case then u shouldnt be hearing anything just as busted said. i ran without backing plates for some time as well....no problems.
          its something else...jack up the car and kick the rotor to see if there is any vibrations or abnormalities.
          Retro!
          Hater
            You probably have a loose caliper bolt and thats what's rattling.
              checked and rechecked
              Ok. Ive checked and rechecked everything. Nothing appears to be loose. Any suggestions? I really dont want to take it to a repair shop because i dont want anybody touching my baby.
