Timing Belt Issue
    Timing Belt Issue
    Yes i have a question about a timing belt issue. The other day i was driving down the interstate and i was running about 75 mph at about 3500 rpm's when my car just died. Now i pulled over to the shoulder and tried to start my car a couple of times and it would not start so then i popped the hood and started checking things. Well i pried the timing cover off and the belt was broke. My question is do you think at the speed i was going and by me trying to start the car i could have bent valves? Also is there any way to check and see if you do have bent valves? I do not want to spend the money to put a timing belt on my car if the chances are that i have a bent valve. Any help would be appriciated.
    chances are good that you have some bent valves the only way to see if you have bent valves for sure is by taking off the head for a good inspection of them. *Edit: another good way to test for bent valves is a compression test.*
    good news is F22 engines are a dime a dozen. all you'd really need (unless the pistons have marks from banging into the valves) is a new F22 head which shouldn't be that much money. You'll also need a new Timing belt (of corse) and a water pump would also be a wise thing to put on wile your at it.
      timing belt breaking
      sorry to here that dude but most likely u bent ur valves. this model accord and other model honda/acuras have wat i believe they call and intermitting engine i may be mistaken. but if ur belt broke and ur engine died at hi rpm more than likely u bent the valves which will cost u. unless u do the work u self by taking a part the head. once again sorry to tell ya dis bro.
        You can do a compression test to check for bent valves, however chances are you most likely did. Sorry to hear that man. I see this shit all the time. I don't understand why poeple don't keep up on basic maintnence so this doesn't happen.
        00 Jeep Grand Cherokee 4.7 V8 4X4
        92 Honda Accord LX
        95 Honda Civic CX
          no worries.... your vavles ARE bent.
          Just go find a head off of another f22 for 100 bucks. Buy the timing belt and h20 pump for 70 bucks.
          Then find a decent mechanic and pay him about 200 bucks.
          BLAMO!
          New(used)head, new belt, new pump for under 400 bucks.
          Dont even pay to have your head rebuilt. That would be outrageous.
          Noobie my ASS.
            I rebuilt my F22b1 head by myself... Pretty cheaply too... Hand lapping the valves is easy, and so is replacing the seals.
            Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
              Sorry to hear about your bent valves (which i'm sure happened). Good news is that you can get a different head, and they're usually a dime-a-dozen. Bad news is all the pain in the ass it'll be to change it.
                just throw some new valves in your head, put it back together and be done with it. Guess you'll be doing your timing belts on time now, huh.
                92 Honda Accord LX
                95 Honda Civic CX
                  well u might wanna check the piston rings and other internal engine components before u do work on the head. chances are u might wanna rebuild the whole engine. the reason i say this is because on my first accord my timing belt went fuck while i was doing about 80miles/hour. i got the head rebuild but after a while driving my car it began burning a lot of oil(one bottle a week but no smoke at all).
                  so u might wanna check other stuff before u start doing any major work on the head.
                  sorry to hear about that shit. u should have checked the timing belt when u first bought the car. it sucks learning stuff by experience man.
                  good luck
                    did anybody else pay attention to his name? he may actually have the h22...if so i feel very sorry for you and your motor
                    although the mph and rpm's coincide with f22 gears...i hope he didn't have a h22
                      well it doesn't really matter now, does it. Whatever motor you may have, if you don't properly maintain it, you fuck shit up......its that simple.
                      92 Honda Accord LX
                      95 Honda Civic CX
                        *timing belt breaks* *valves bent*
                          Just to let you all know the timing belt was changed about 10k miles ago. So the only thing i can think is maybe the belt was defective when we put it on. and yes it was a h22.
                            Only 10k miles... dang
                              damn.. sorry to hear were the tensioners also replaced w the timingbelt?
                              No projects at the moment... danm
                              2k20:
                              For sale Demon+ tunerview RD2 Make offer brand new in box
