So I did my valves last night and all was good. Today I get a loud ticking and pop the valve cover again. I lost a nut that holds the adjusting screw. I cannot find it anywhere up top and am thinking (hoping?) it went into the oil return passage way. FWIW, this was the exhaust side #1 cylinder and the valve closest to the outside of the engine.
If that is indeed what happened, the nut SHOULD just stay in the oil pan, correct?
Thoughts? issues? concerns? Replacement nut should be a Grade? (8?)
I'm so happy right now I could just sh!t.
