1. I have ABS and I have to change the cotter pin on my shift linkage. h22sparkle broke the old one off and left the hole plugged. Can I remove the ABS module temporarily (w/o disconnecting it) to get room to drill out the old linkage?
2. My tranny is leaking badly from the right axle. I'll check the Haynes when I get home but does the tranny have to be disassembled to change the axle seal? What would cause a leak around the CV joint?
