idle and signal problem..
Adjust your FITV. Just screw it down.
My car if i dont step on the break, it idles at 7-800 rpm..Whats the tps?? this only happens when the break is step on..Originally posted by wrichards2005What is your car idling at? Check your idle screw to make sure its inl, if not that, disconnect your TPS and see if it stops, it could be that or an IAC valve.
I did that already, And couldnt solve the problem..Originally posted by NAiL05Adjust your FITV. Just screw it down.
TPS = Throttle Position Sensor. Hows your coolant level? That can cause a fluctuating idle in some hondas and if it has air in the system. SO if you dont touch the brake at all it doesnt fluctuate at all?
If i step on the brake it gives me that idle, if i dont then it stays at 7-800 rpm..Coolant and everything is fine..the car did this even before i got it..Originally posted by NAiL05TPS = Throttle Position Sensor. Hows your coolant level? That can cause a fluctuating idle in some hondas and if it has air in the system. SO if you dont touch the brake at all it doesnt fluctuate at all?Last edited by StockAccord; 11-27-2006, 12:31 PM.
