Torque Specifications.......................Ft. Lbs.
Balance Shaft Pulley Bolt.....................22
Belt Tensioner Adjuster Nut..................33
Camshaft Pulley Bolt...........................28
Connecting Rod Nut............................34
Crankshaft Pulley Bolt.........................162
Cylinder Head Bolt
Stage 1............................................29
Stage 2............................................51
Stage 3............................................78
Drive Plate (Automatic Transmission)......55
Flywheel Bolt (Manual Transmission).......77
Exhaust Manifold Nut...........................23
Intake Manifold Nut.............................16
Main Bearing Cap Bolts/Bridge
Stage 1.............................................22
Stage 2.............................................55
Oil Pan Bolts.......................................10
Oil Pan Drain Plug.................................33
Rocker Arm Adjuster Lock Nut................14
Rocker Arm Mounting Bolts
6mm Bolt.............................................*
8mm Bolt............................................16
Torque Specifications.......................INCH Lbs.
Oil Pump Cover Screw...........................62
Oil Pump Housing Bolts..........................80
Valve Cover Cap Nut.............................90
Water Pump Bolt..................................106
* Tighten to 108 INCH lbs.
Cylinder Head Bolt
