help. possible electrical problem on H22!!!!!!
    so, my battery terminal has been getting corrosion and fuzzy stuff on it, so I thought it was just the battery but on the battery housing on the bottom, the 4 bolts are also surrounded with the same fuzzy stuff and so does the negative line that connects to the engine also so Im assuming that its not the battery leaking. so what could cause this problem. what should I check, I have already7 tried cleaning up these mentioned parts but few weeks down the road it starts getting the stuff again.
    put some new cables on it and a new battery
      clean up the terminals with some coke and baking soda or w/e weird combination of products people use.
      Deev can tell you all about corroded terminals.
        cleak up the terminals with a wire brush and throw some gingerale soda on the terminals to slow the corrosion.
