Does anyone happen to know what size the high and low pressure fittings are? I want to get some brass caps as the schrader valves may or may not be leaking. Those plastic ones are pretty useless......
Air Conditioning Fittings
Lets just say even with new lines I'm having a bit of trouble with them. The caps seem like the easiest fix (and they're cheap).Originally posted by DrLove'sKuDang
arent the plastic caps just for covering anyways??? the nozzles shouldnt leak unless the center pin is pressed in right?
Actually, if you look at the "stock" caps they do have o-rings in them.
EDIT: Schrader valves blow!Last edited by NutBucket; 05-03-2004, 06:41 PM.
