Custom Porsche brake swap
    We all know the accord brakes suck big time, so i decided to upgrade em....
    current setup:
    Accord wagon rotors (hub over rotor design)
    Lude vtec Calipers
    near future:
    296 mm willwood discs (slotted) 32mm thick
    Custom alluminium hart
    Porsche 996/Boxter calipers (4 pistons)
    Custom bracket
    Honda legend master brake cylinder
    brake ducts
    Some picīs of the mockup i made,
    MORE PICīS IMAGESTATION......
    if this wont stop me.....
    updates will come in due time
    Greetz,
    Dutchaccord
    special thanks to USC, providing some picīs
    No projects at the moment... danm
    2k20:
    For sale Demon+ tunerview RD2 Make offer brand new in box
    1. Holy crap.
    2. Want to sell me your old brake setup?
    3. What are you going to have to fabricate to mount those Porsche calipers?
      Awaiting my tax refund....
      project should be finished by august.
      @Slateboy
      2) my current setup is already sold....
      3) the brackets will be made of 7075 alcoa
      Stefan
      2k20:
        If you're going to CNC machine those brackets, you should chop me up a set. $$
          a few teaserpic's:
          DAUMENDICK !! ghehe 32mm a tad overkill?.....
          Finally i can proceed....... aditional steup CAN be made.....
          2k20:
            Damn, that is over kill! I like your DOHC VTEC sticker too, its tasteful.
              finally got those discs in!! look great man.
              why do i remember seeing a pic of a caliper mount bracket already made...?
              anyway good luck with it, ive been following all of your porsche brake threads since the beginning.
              btw i want your sidemouldings
                got some more work done, finally getting somewere (sorry for the bad pic's... it was getting dark, had to take them quick)
                I decided to go with porsche 964 (4 piston) calipers, they had the best fitment and wil fit ANY rotor thickness
                sitting in the trunk
                the calipers need to be widened 3mm to fit the willwood disk
                the old rotors are used to fab a temp. test heart..... ultimatly it will be machined out of 7075 aircraft grade aluminium
                more updates SOON (atleast that's what i hope)
                feel free to comment-flame-ask
                IMPORTANT NOTICE FROM IMAGESTATION
                Sony ImageStation is currently unavailable for use. The site downtime is only temporary and is part of our ongoing efforts to improve the ImageStation service for your better enjoyment.
                We apologize for any inconvenience this may cause you.
                Thank you for your continued support,
                The ImageStation Team
                2k20:
                  i never made a caliper mount... (i think ur mistaken by the pic if USC's car)
                  EDM sidemoldings are rare... even in Europe....
                  2k20:
                    i've seen your caliper bracket made as well. i'm sure it was you since you are the only one crazy enough to put porshe brakes on a 4th gen. you sure your DIY hands didn't tell you that you made a bracket?! hehe jk! good job on the brakes. just like cpmike, i've been following your thhreads since the beginning. dang i want it to be done already. the ultimate DIYer strikes again!
                    1cor10:31
                    - 92 LX coupe
                    - 96 EX wagon (sold)
                      This is going to be awsome when it's all done
                        That's the truth.
                          Hey dutch i have a question, will the wagon rotor wit on my 92 coupe hub? I want to install them and im not worried about the caliper i have ones that will fit. But just wondering if the rotor and caliper is the only thing I need to swap.
                          To have loved and lost is better than to have never loved at all #CB7Life
                            yes the wagon rotor wil fit the hub, the only thing u need to check is the caliper bracket... T23 or T25... not shure wich one dont remember, u'd have to look into that, the rest bolts right up... goodluck
                            2k20:
                              did some more work today
                              did some research on the caliper bracket. I need to remove the original mounting points and drill/tap some new ones perpendicular to the original mounting points (caliper). There is plenty aluminium to do this
                              the caliper clears the wheel by bout 12-15 mm in diameter, but needs some more room to clear the spokes..... the disk needs to be bit further back in ----> to far and it'l be hitting the lower arm
                              Too bad the rim's blocking the vieuw to the caliper.... let say it ads to the sleeper look
                              2k20:
