Overdrive not working
    I finally got my new auto put in but now I cant get the o/d to work. I pulled the TCU and no burnt resistors. I adjusted the cable that goes from the intake to the lever on the tranny. When I do that it works for a minute and pops out again and doesnt work for the rest of the time I am driving it until I adjust it again and the process starts all over again. I made sure everything was hooked up correctly. The TCU is throwing NO codes. Does anybody know what the hell is going on?
    anybody?
      maybe something isn't sitting right and it can't PHYSICALLY go into OD. cable have a kink or anything in it? just a simple kink/crimp can mess it up.
      if it's going but not kicking in, it could be related to the torque converter or even the tranny itself.
        Well its funny how the old tranny did the exact same thing and the new one is like beautiful and it shifts buttery smooth unlike the other one. I quadruple checked everything to make sure it was all correct. I adjusted the cable like I read on here somewhere. And it still does not work. Could it be the switch inside the shifter thats doing it? I noticed that it only kicks in after a launch and will stay in for a minute then cut back out again and the process repeats. Im going to put my old "burnt resistor" ecu back in and see what it does....im very doubtful.
          If your engine is not getting up to the right temp it will not go into overdrive also. Sometimes the thermostat is not working right and it is not quite to the right temp. Just an idea?
          The 90 Accord 4DR Sedan my son and I are building.
            hmmm...NONE of the resistors are bad?? thats really weird. if nothing else, maybe take it to a transmission shop and have them look at it. unless its really expensive, i dont know what that would cost...
            yeah so that didnt help at all sorry man...good luck tho i wish u only the best
            "This truck is 100% sh*ts and giggles."
            "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
            You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
            Disregard females, acquire currency
            BUS 62 AIN'T F'ING AROUND!
