Coilovers?!?! Which rate goes where?!?!?!
    I just got some coilovers and there are 350 and 450 progressive spring rates? Which rate goes where? and there are all kinds of rubber washers! Anyone know where they go? Please lemme know asap! Thanks!
    what happen to the instructions that came with it???
    also if their TRUE coilovers, u can adjust the spring rates(well the more pricy coilovers can)
    "You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
    I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
      Usually the stiffer ones go in front. Rubber washers or O-Rings?
        ^^^i 2nd... higher spring rated do go in front. and im assuming you bought some ebay coilovers or "sleeves" that go over shock? those black o-rings slide over the shock base and help keep the coilover in place.
          yea it is just a sleeve kit, you cant adjust the rate the spring just has the rate on them. there are 2 springs with 350sr and the other 2 are 450 spring rates.
