Check engine light after HUGE pothole
    i hit a really big pothole and my car drives fine doesn't look messed up at but i have a check engine light. do you think resetting the ecu will fix it.
    JDM H22a
    P2T4 tranny
    I/E, CM ultra-light flywheel and CM stage 1 clutch
    16x7 Rota C8's in bronze
    nitto neo gen, 205/50/16
    custom short throw shifter
    Tokico Illumina RAK Coilovers
    Power Stop Cross-Drilled Rotors, Honda Pads
    Honda Torneo Shift Boot and Knob
    i suggest you try it... hehe
    if it comes back after you reset the ECU, follow the procedure to get the check engine light error code, and report back to us.
      id diagnose the problem and find out what is triggering it then reset it iMO
      Retro!
      Hater
        Maybe it jumbled wiring/connector loose.
        I'd reset it, then if it comes back..check the codes and most likely that wiring/connector is loose.
          I'm going to have to agree with 'Ztech... It's pretty simple to at least retrieve the code first, THEN reset the ECU. You want to know what the code is before trying to erase it, because it may be a harbinger of greater problems if not addressed immediately. If you don't find the reason for the code, just PM me with the number of flashes, and I'll translate for you.
          Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
            Good point Kabuki. Like the 91 SE ABS prob that I had, the light came on and when I found out you can check codes for it, it never did it again.
            Which does not mean there wasn't a problem to begin with, we did have vibrations related to the braking system and we would have found out if that was fixed, but my dad smashed the front end into some lady. Didn't even drive it that far from Honda dealer when he caused this.
