trouble codes
    trouble codes
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor
    65 Secondary oxygen sensor heater
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    repost but never a bad thing to have doubles of
      sorry i searched but couldent find any so i thought to post it up
