Alright!! I finally got the 92 EX on the road, it is running like a beauty, just some minor wiring glitches (like the Rad. Fans not turning on when the ignition is on).
I'm having a problem keeping the coolant temperature at normal operating levels (200F). If I let the car idle, it will sky-rocket to 260F, and the fans never kick on unless the ignition is off... but if I DRIVE the car, especially with our -10F weather, even when it is only 30F outside.. the coolant temp drops all the way below 100F. (I have an aftermarket temp guage).
I am thinking it might be the Therm. is stuck open, and that maybe the radiator is a little bit too large for the car. After driving it for a while, and the engine is hot, if I sit at a light long enough, I will see it slowly climb above 100.
What would be a nice quicky solution for this. I am thinking of maybe getting a piece of plexi or something and blocking part of the rad. What would you guys think??
I never thought I would have a problem with under-heating of a car... it's always over-heating!!
Kev
Kev
