Hi guys.
We're working on a 90 CB7; Guy said performance problems. We checked the timing it was off so we fixed it. The red mark is now dead center on the pointer when timing gun is set to 00 Deg BTDC. We checked the cam timing to be good; when cam pulley is set to TDC, white mark on fly wheel lines up with pointer. but, when you set the timing gun to 15* BTDC, the white mark will not line up with the pointer. cant even see it. any suggestions?
