pls help! cruise control~
    hello guys,
    i got some problem i couldn't solve.
    my cruise control was working fine before i had 5spd swap.
    i got the manual cc computer and manual ecu
    but still couldn't make the cc work.
    it did rev and speed up for few seconds but
    then the rpm went all the way down.
    what should i do to make it work?
    any inputs will be appreciated.
    my member's ride thread
    check the vacuum lines and throttle cable
      The VSS (vehicle speed sensor) needs to work for CC to work... I think VSS throws code 17 when it's bad.
      - Ghosty
      WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
      FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
        On the five speeds, There is a plastic stopper in a hole on the top part of the clutch pedal. (just like the one on the brake pedal that actuates the brake light). Make sure that stopper is there, if not, plug the hole with something. Cruise control disengages when the clutch or the brake pedal is pushed. If the stopper is not there, the computer thinks you're pushing the clutch.
        PURCHASED NOVEMBER 1991. THAT'S RIGHT, I'M THE ONE AND ONLY OWNER. BEAT THAT!
          i don't exactly understand what you want me to do but
          everything's fine except the cruise control.
            no code 17 and the speedometer reads correctly.
              seems this is the answer.
              but i removed the clutch pedal from one without cc,
              does it also have a stopper?
              i know that some people have push the clutch when start their cars
              but i don't have to with my cb7.
              the tranny is from a twdm cb and the model is h2s8.
              one of my friends has the same tranny and his cc work fine
              after swapping the mt cc computer.
              i'll check if there's a stopper and see.
                good news and bad news~
                the cruise control does work right now but
                it keeps going when i push the clutch.
                is there some sensor on the clutch pedal?
                  yes there should be a cruise control switch on the clutch pedal, along with your clutch safety switch.
                  the cruise control switch is supposed to disengage the cruise control.
                  F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
                  Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
                  Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
                    cool~
                    then is it able to get the switch?
                    i asked some local shop and they don't even know what it is.
                      Hit up a junkyard... Looks exactly like the other clutch switch and I think the brake light switch. Grab the switch with a bit of the pigtail and wire it up to your cruise control box (pink wire and ground)
                      Originally posted by Junior Smurff
                      Nevermind guys, google search works wonders!
                      I don't have road rage, my car just goes faster than yours!
                      Accords are for winners. And Grandmothers. But mostly winners.
                      I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
                        thanks for the info.
                        will try to get one and see.
