well if it isn't one thing, it's another. and apparently now my battery cables are screwed up possibly.
the car has no power, even the stupid clock isn't on, and when you try to turn it over the battery light comes on along with seatbelt and brake (e-brake). but when I went to charge the battery, the battery is already charged.
and I had run the car just a few days prior to it failing to start. the battery cables do look to have some corrosion but the terminals are not corroded, although one has a slight bit of rust on the outside.
also, I just bought the battery at the end of august. so it's practically brand new.
so at this point, battery cable replacement may be in the mix.
just want any comments on types of cables people prefer, also, if they make red ones, so I can start to color match the cables to the paint. rofl.
