94 honda accord lx
    94 honda accord lx
    ok trying to replace the flasher for my friend he said he has it.. okay i'm assuming the blinkers and hazard are one flasher.. well i think i located it.. its to the left of the clutch pedal right.. goes into the fuse box... well im having trouble pulling it out.. i tried wiggling it side to side.. theres like a little tab on each end i pushed it while pulling it out still didn't work.. whats the correct way.. thanks
    http://www.get-gifts-for-free.com/?ref_id=4810
    1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
    ttt anyone. i know someone have done this before..
      yeah it's called a blinker relay and yes that's the one. hit the hazard and you should feel it clicking. i usually use a flathead screwdriver to remove it. it is a PITA for sure but just keep at it after releasing the tab. you only have to release one side then wiggle.
      1cor10:31
      - 92 LX coupe
      - 96 EX wagon (sold)
        Yea a flathead would work fine or fuse pullers.
        Project EP hatch on the way
          ok its not the flasher swap it out.. hazard fuse on the fuse under hood is good.. all the light bulbs works.. funny thing is the hazard light will work along with the dash. but if u put the turn signals it doesn't show on the dash nor will it blink but hazard work.. only fuse i didn't check is kickpanel didn't try that because i don't think theres one.. plus theres no fuse panel so what should i look for.. i'll just pull out whatever amp u guys said it might be.. also try to give me direction where it could be located and number of amperage..
          thanks
