Just don’t understand….. I have an issue with my cluster and seatbelts. For some reason or another, my damn cluster in not working at all. No anything for that matter. Also my damn seatbelts in my 91 accord EX (Same Car) will not slide back. I know it’s not the release switch that’s on the door catch. Both of my issues have to come from the same problem. All my fuses under the hood and on the kick panel are fine… WTF anyone have this issue or know what it could be? I did think it was the main relay at first but I did change that out with one from a working car. Still no fix for the issue…. Help
Inside issues (Need a fix)-_- Help
Check the auto belt control unit under the passenger seat. There are two plugs to it and I have heard the box occasionally goes bad.Retired 1990 Accord LX Coupe
Project 240SX
Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, roskoOriginally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
Fixed
Problem fixed, well half way.... Everything is back up it just that I think I got a short in my pass side SB I can find that with no issue.... The after going over some past post from others.... I found that all my fuses were good, I filled the slots for spare fuses and bamn it happend everything came back on.... I think its crazy... I never took anything out but it used to work...WTF
Thanks to everyone that helped....
