after driving for about 20 minutes my oil light starts to flash on and off. this never occured until i boosted the system, which leads me to think of two possible reasons: the oil is getting too hot, or oil pressure drops after driving for a while. if the oil is starting to boil over, buying and installing a oil cooler should do the trick right? but wat if it is the oil pressure declining? wat then?
oil light flashing?
sounds like you are just low on oil but i'll assume you left that out because you already checked the level and know for sure that you have the required amount
1993 Accord LX - Sold
93 BMW 525it - SOLD
92 Accord EX Sedan - SOLD
2000 Accord Coupe - Traded-In
2003 Accord V6 6spd Coupe - Sold
2001 Honda Civic Ex - SOLD
2013 Chevy Traverse LTZ - Kid hauler
2003 Acura Tl 3.2 - Daily Commuter
Flashing means it has had a momentary drop in pressure NOT that it has lost all oil pressure (thats a solid light).
Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
Originally posted by slammed4thgendustin, you are a dick!
officially the lowest ive seen now
It's a pressure light--you can have full oil level and still have pressure problems.Originally posted by StinkinLincoln View PostMine does the same thing when I drive it sometimes the oil light will blink but when you check it it is FULL...Probably a Bad Oil PSI Sending Unit!!
Sorry to wake up the dead!!!! lol
In you case tho it's prob. a faulty sensor. But until you change the sensor you won't know-or until you put an oil pressure gauge in.
