I've noticed several times over the last few months when I check my fluid levels, there will be power steering fluid on the top of the reservoir. I'm not talking just a few drops ether, I mean it's covered in fluid, and it's dripped down onto the inner fender, and there will be a little on the ground. Does anyone have any idea how fluid managed to leak out of the top of the reservoir, because this is puzzling me. I didn't think there was that much (if any) back pressure in the power steering system, and I can't imagine that I take turns hard enough to force the fluid past the cap. BTW, a mechanic across the street from my mom listened to the pump, and said it sounds fine.
Odd power steering leak
the system is pulling air in from somewhere causing it to froth and bubble over. check the system again when the car is on and see what is happening in the reservoir.
My power steering lines are corroding and have several pin hole size leaks. When the system is under pressure, they shoot fluid about 18 inches. See if you can see a leak while its running (turn the wheel lock to lock several times).
