I want to get a chipped ecu for my NA setup. I don't have a cam yet but I plan on getting either a delta or bisimoto. I know a lot of people get the p06 from the civics and I was wondering if I could get a virgin p06 for $60 is it worth it? Also, what would I have to do to chip it after I get it?
p06 question
p06 question
R.I.P. CB7; hello spec-v!
Member's Ride
FS thread: full part-out
Help me with my spec-V fund, buy my stuff!!!
Degree of rice and performability are inversely related.
Tags: None
F22a1 I/H/E, Apex'i SAFC (which I intend on removing if I get a chipped ecu).
The only problem is I don't know how to go about chipping it myself. The soldering part is not hard, just knowing what to do.
I guess my question is, would it be worth it to get the p06 and chip it myself or would it be better to buy one already chipped and tuned?
edit: oh and 5 spdR.I.P. CB7; hello spec-v!
Member's Ride
there are few member on here that will chip the ecu for you. d112drzy is one of them and it seems like he knows what he is doing so contact him.The CB9 has been reborn into a CB3
Members Ride - see my cb3 here - DOHC powah
Check out my JDM F22B swap
Watch my CB7 video
Average price for virgin p06 ecu is about $50. Then, you send your ECU to a guy that can chip it and hopefully give you a decent basemap for your setup, enough to start your motor/run it to the dyno to get properly tuned. That is the process. For I/H/E, intake manifold, throttle body modifications I'd stick with stock ECU, but once you start throwing in camshaft(s), then get a chipped ECU. Heck, even significantly improving your intake system with bored TB and ported IM, I bet a chipped ECU may help as well.
Well I'm definately going to be getting a new camshaft some time in the next month or 2 so should I get that before the ecu? because it won't run very well with the cam and no tuned ecu will it?R.I.P. CB7; hello spec-v!
Member's Ride
Oh ok. I guess I'll get the cam first then.R.I.P. CB7; hello spec-v!
Member's Ride
