okay guys i just want to get a few things straight. plz answer or correct me on theses ecus.
the p14 ecu comes out of the h23 prelude but the p12 also comes out of the prelude and im assuming it has the f22 motor. i have a pt6 ecu in my car right now. is the pt6 the same as the p12. does the p12 have a speed gov, and does it controll duel runners. does the p12 have a more aggresive fueling map than the pt6. i know the pt6 and p12 redline the same. when i swaped the p12 the check engine light did not come on, but i was expecting it to because i thought you need a knock sensor. now where does the p14 redline and does it have a speed gov? im trying to figure these things out because i did the h23 head swap and im wondering what ecu is best. what about a chipped po6? thanks.
