Ok, I wanna know where the plug is for a computer scan..I was gonna run a scan with our computer equipment at work today, but I got soo many wires, that I cannot find the damn plug. I know it's under the driver's side, but other then that, I got no idea. Basically, I need it to scan where my vaccum leak is (if that's possible) since my motor revs and stuff. Also, more importantly, I need to know what my issue is with my passenger window. See, I replaced the lock actuator, but now the darn door's window will not roll down! The pass. button go up, and the window wants to go up (even though it's shut) I push the same button down, and it will not roll down. The driver's window button for the passenger window( I think it's called the master switch) will not roll the window down or up at all..the driver's window works just fine, but the passenger can't be controlled by either switch, except by the passenger switch, and only going up. I dunno what it could be..? no, the driver's safety lock is not on, for the power to that window, and I know it's all reconnected...man, it is hot around here too..btw, it's a 92 ex coupe..
-A. Swift
-A. Swift
