Hey all,
Summer's coming and I want to get my AC system working. My buddy pressurized the system and it held R134, but my compressor wasn't kicking on when I pressed the button on the dash. We drained the system cuz it was the other day and today we fooled around with the compressor. Plugging directly into it the clutch would kick on and the compressor would work, but there is either a broken wire or a bad thermostat that is stopping it from working using the dash controls.
Has anybody else had this problem? The compressor works, but it won't kick on from the proper control mechanism. My buddy said he's never had this issue with Honda's before; they generally aren't working cuz one of the main components is busted i.e. compressor/condensor, not an electrical/wiring issue. So he's puzzled and I don't know the first thing about AC.
Anybody got suggestions? Thanks in advance
) so I'm hoping its just an inexpensive thermostat unit that will be easy to change and replace.
I think that if you applied ground to it and it kicks on, then it may be a ground issue. I could be wrong.
