What is the problem? When I try to put it in 1st it doesnt engage, I have to pull off in second now and then shift to 4th since 3rd doesnt work and neither does 5th. what can I do to fix it?
Shifter wont go into 1,3,or5th
See if cables are binding up in engine bay.
Well I went and checked the linkage for binding and it wasn't that. Im not sure what it is now since I had my girlfriend moving the shifter to each gear and tried to look under the hood while she did it. The one in the back pulls out and goes over but the front one goes over but doesnt stay and it isnt hitting up against anything because it worked before. Any takers on what else could be wrong?
syncro's mayb?
How bout the cable itself? Sometimes it could just be broken. Doesnt sound like a syncro problem too me if all three gears crapped out all of a sudden.
My friends car did the same thing, and believe it or not, it was the motor mount. The bracket came off the frame...but I doubt that's your problem.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
So move it by hand and see if it engages. Only other thing I would mention is slave cylinder since that controls most of the engage/disengage clutch deal. But you said 2/4 go in fine.
Yeah, 2nd, 4th and R work fine. When I put the shifter in first, it has no click feel to it. It just goes back to the neutral position, same thing for 3rd and 5th. So could be the cables but they worked fine 3 days ago. Its strange.Originally posted by NAiL05So move it by hand and see if it engages. Only other thing I would mention is slave cylinder since that controls most of the engage/disengage clutch deal. But you said 2/4 go in fine.
