Idle Update
    Idle Update
    Alright well my eratic idling problems happen only when my car gets warmed up and in low RPM's when at WOT I have no idle problems.I just recently remembered that when I didnt have a fuelfilter I tried caping off my fuel line with a vacume plug and well it was realy small and fell in.I then turnt ther car to on to engage the fuel pump and im not sure if it came out when I did that.
    So would that be a cause of my eratic idling??? If so how can I get flush my lines???
    Thanks in advance
    i hear having air bubbles in your coolant system can cause idle problems.
    try bleeding the air out of that to see if it helps.
      ok, check it out, ima let you in what i did with mine, get a hold of a thick manila folder, place your FITV valve on top and trace it, cut it out, punch out the screw holes and place in between the valve and manifold(kinda like a gasket), then just bypass the coolant lines and your good to go on that one
      also check your coolant sysem for any air trapped, your EGR valve for it's condition and make sure your IACV is working properly....
      that should take care of you
      THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
      My Ride thread
      Flickr
      Originally posted by d112crzy
      And it can only get better. That's the best part.
      All I gotta really say is:
      People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
        Ill do that tomorow, I was messing with my car a little more today and this is what ive come down to.
        It starts to idle eraticly only when it gets worm.But if you start it and its cold, and then press the brake peddel down or turn on the high beams it will surge.
        Also when ever I press down on the brake peddel the light on my cluster stays on.
          also, make sure you have NO vacuum leaks. that will DEFINITELY cause it to do it also.
          My Ride thread
          Flickr
