idle prob (OBD2 to OBD1)
    Well I posted before about my F20B SOHC VTEC motor and its a OBD2. Well Anyone know what can i do to make the motor run normal without idling. I cant change manifold. Since There are no aftermarket one for that motor. Any idea what can i do?
    plus the mechanic did a horrible job on the setup.
    1992 Honda Accord EX My Ride Thread H23A BLUE TOP Complete
    Holy crap!!!!!!!!! he did do a shitty job. or excuse me, I mean he mickey moused it. that looks like the iacv on top of the intake. wow. speechless.take a few more pics without the strut bar in the way. maybe we can better assist you better. and between the intake manifold and the firewall too. maybe under the t body too. sorry, too much to ask for. but I will take the time to try my best to help. and other's as well. good luck and thanks.
      I would say clean your iacv. That could be the issue.... I am have'n an issue some what like your.... I cleaned the iacv and it didn't do anything...... Cleaned it again.. and it kinda when to a steady 900RPM.... So It may help you out for starters...... You should still be able to adjust your idle for your ride with a screw-driver
      My Members Ride Thread ( Do It )
        posted more pics
          I think the iacv is on top of the intake next to the throttle body that isn't even hooked up correct. I believe it should be on the back of the intake manifold.
            theres more than one thing not hooked up properly.
