okay im dropping my transmission out, so far i cant seem to get the lower ball joint apart from the lower control arm, i've read people saying that BFH should do it. is this true? i've been pounding away at it for a while now... also i kind of skipped around steps and i've taken off the drive plate bolts and i havent taken off te transmission housing bolts ( bolts to the engine ) does that matter? do i have to completely remove the front dogbone motor mount? or do i just disconnect the bolt from the top end of the motor mount to the engine mount? also i don't have a tranny jack so can i just use my low profile 2ton car jack to jack it up and down? do i have to tilt the engine downwards somehow to get the transmission out? any help would be great, thanks.
help please dropping transmission
you do not have to remove the dog bone, just the tranny mount. use a puller on it and will come out way easier, yes you can use the floor jack to support and lower the tranny mount, from my experience i didn't have to till the engine, i belive you do have to remove the strut rod though
where in the desert are you located?
you dont need to remove the strut, just disconnect the fork from the lower control arm and continue banging away at the control arm area where it holds the ball joint. it also helps to put the jack against the arm and push it up every once in a while to put tension.
while it is not necessary to tolt the engine, it does help because the transmission will come out at an angle.
to put my tranny back in, i used an ATV/Motorcylce jack with a 2x4 supporting one end of the transmission.
the only issues ive had so far is lining the transmission back up and getting the tranny and engine to bolt in but with enough force it will go in. (that makes the 4th clutch job ive done :o )
time to go do a ae86 clutch
the lower ball joint sometimes gets frozen in there- i used a tuning fork and a bfm. just becarefull not to destroy the rubber gromit thats inbetween...Originally posted by 19accord92i cant seem to get the lower ball joint apart from the lower control arm, i've read people saying that BFH should do it. is this true? i've been pounding away at it for a while now...
Bought from: 92acclude, almostJDM, cali-racer, MikeW, rexload, slick, sackingz123, so-calsfinest, lindiz, yeamans17
Sold to: timmy0tool, sackingz123, judonoh, jdmhondaman, jdmaccord91,Ofr
mycb7.com
Members Ride
