running lean but consuming gas?
    ummm, quick question for you guys...my spark plugs indicate im running a bit lean yet my mileage isnt the best either (average about 21mpg)
    ive done pretty much every maintainece thing required, timing is dead on at 15.
    reason why i ask is that my fuel pressure was measured at 27 and about 34 when the fuel pressure regulator vacuum hose was disconnected.
    the readings are a bit low according to chiltons, Alldata and even the helms that i have. so that would indicate a fuel pump issue right? my main relay works minty fresh as well, starts up every single time.
    things ive done:
    -ignitor
    -cap
    -rotor
    -spark plug wires
    -spark plugs
    -fuel filter
    -egr
    -air filter
