my h22 is missing and i can't figure out why..
the only cel code is 12 but i have had that stupid egr code since i did the swap and in low gears it misses, and driving it misses.... but you gun it it runs hard and fast with no miss,, but when you put it in park it starts surging... could this be a bad tps sensor? a sprayed carberator cleaner all around all hoses and intake and no leaks!!??? what could it be
j/k. I just had to say that. anyways, with a bad egr valve, is can cause it to run funny. Disconnect your egr connector and then drive it. if it fixes your missing, then replace your egr valve.
