Broken spring
    Broken spring
    i recently found out that my front left driver's side spring is broken. i've found someone that has a 97 accord would the front strut/spring combos be able to fit my 92 accord. also would there be a difference between abs and non-abs models.
    if i change the whole shock and spring assembly would i need a spring compressor and how difficult would this procedure be.
    would i also need an alignment after changing the struts and springs
    A spring compressor is definately a reccommended investment, which can be had for under 20$, however its not required. An alignment would be benificial too, but not recommended. Yes, the springs/struts from the 97 accord will work, however now is your time to go aftermarket as it will most likely be cheaper than OEM parts.
      If you need good condition, no rust, no fracture OEM springs for 90-93 Accord, contact me via PM. I have a full set. I'll sell for good price shipped.
