When turning kind of sharp through intersections going to the left I will hear a thump, thump, thump, on every rotation on the tire on the passenger side. I was wondering what the problem could be? I just had my axel's replaced if that means anything. Thanks for any help.
Sounds while turning?
Steering wheel change? as in movement?
also, has you handling decreased?
Steering wheel 'bumping' could be a c/v joint, but not likely since you just got the half-shafts replaced.
Decrease in handling could be the bushings on your sway bar.
None of these could be your hub-bearing? dont remember the right name. But the bearing that is inside your hub that holds the disk. Pain to replace with a press.Last edited by Direthought; 06-22-2007, 09:33 PM.
How about the C/V boot? Got the same sound and was told (but haven't looked yet) that it's the rubber boot.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
Originally posted by boulderWhen turning kind of sharp through intersections going to the left I will hear a thump, thump, thump, on every rotation on the tire on the passenger side. I was wondering what the problem could be? I just had my axel's replaced if that means anything. Thanks for any help.
your ball joint is going out. it will be your upper ball joint that is connected to the spindle. THere is a DIY to replace these. Also you can rent a tool to remove it. don't just use a hammer and force it out. do it properly and do it correctly
either kill it or drift it...
2002 Toyota Tundra V8
I vote balljoints.. GET THEM REPLACED ASAP!!! They very dangerous once they are starting to go out. Unexpected will happen.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
