Anyone, know how the hell to replace the high pressure hose, underneath the car, i can not see where it ends, what tools do i need, and how the hell do i change that bad boy???
Replacing Power Steering High Pressure Hose
it should go to the steering rack, u have to find the steering rack, then on the drivers side there is a pan on the steering rack, take off the pan and you will see all the lines that go to it.
make sure u use a flare nut wrench or a crows foot wrench so you dont strip the nut, once they are stripped they are hard to get out.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
It kinda loops around on the bottom, it is a hardline, you should be able to trace it back, it just is connected with a screw that you should be able to take off ( i cant remember which size ) but make sure the power steering line is drained first, or it'll be extremely messy, why are you changing the line?
Get underneath the car with a good light OR if you have someone handy get them to wiggle the high press hose and you should see it. Just take it off from there. And the pan ztech mention is like 3 10mm or 12 mm bolts I forgot. Ztech covered most of it though.
yeah one of the lines i just replaced, i believe it was a 12mm...not sure the biggest one down there, it is bolted in then the other end is clamped to a soft line
