I was wondering if anyone has tried to put the manual type seat belts out of a 92-93 in to a 90-91 w/ the passive type. The pillars for the mounting may be different? I'd like the manual type belts in my 90.
Thanks
Colin
Thanks
Colin
If you work at the yard and you get a spare chance, just take the trim panels off of the B-pillar, and you will see pretty much what you have to do. I just tried to use as many of the original holes over. The bottom part is a bit different and thats where it would be benefitial for you to make a bracket that would fasten to the two stock points, and then have the new points mount into that. If you see it, It makes sense.. without lookin at it, I prolly am not making sense. I'll see if I can find a diagram in the helms.
