Lately, within the past 2-3 months, I've noticed when I checked/ look at the bottom of my spark plugs, #'s 2,3,4 were covered in oil, up to about half way up the thread of them. What's the problem?
Problem with spark pluggies.
rocker arm assembly o-rings are shot, more than likely. replace and be on your way. but before you ask any more questions i would run a searc. there are DIYs on threads on this!
good luck,
SeanF22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
True. Other possibility is the piston rings are cooked but I doubt it it's your case. But mostly will be your rocker arm rings.Originally posted by SMseagren83rocker arm assembly o-rings are shot, more than likely. replace and be on your way. but before you ask any more questions i would run a searc. there are DIYs on threads on this!
good luck,
Sean
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
Are they tough to replace. Imma go look at Haynes, to see what they say. Thanks.Originally posted by f22cb7lxTrue. Other possibility is the piston rings are cooked but I doubt it it's your case. But mostly will be your rocker arm rings.The Lord watches over me!
- D. Chappelle
Originally posted by Stright SuccessAre they tough to replace. Imma go look at Haynes, to see what they say. Thanks.
heres a DIY , I have no experience regarding rocker arms o-ring.
http://www.cb7tuner.com/vbb/showthread.php?t=9300
looks easy but if you aint comfy have a experiend friend or a family member to help you out..
I got my SP covered with oil to but , it was my top SP tube seals that were shot. hey, if I were you change the upper SP tube seal to while you're at it.
just gotta take off the rocker arm assembly....it really isnt tough if you follow a haynes. just torque down in the correct sequence! and work on the car when its completly cooled down!
Well, I just did my timing belt and WP. In the process, I changed the upper ones, because they came with the package, and the old ones were shot. Imma replace the plugs and see if that solved the problems. While I'm at it, name everything, if possible ( if y'all don't mind), that I should do for a 100,000 mile tune-up. Thanks.The Lord watches over me!
- D. Chappelle
valve adjustmentOriginally posted by Stright SuccessWell, I just did my timing belt and WP. In the process, I changed the upper ones, because they came with the package, and the old ones were shot. Imma replace the plugs and see if that solved the problems. While I'm at it, name everything, if possible ( if y'all don't mind), that I should do for a 100,000 mile tune-up. Thanks.
