where is it located at? trying to bleed my MC after i replaced it.
clutch hydraulic system
Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-Tags: None
You bleed it from the slave cylinder.
i was and nothing was comin out. book says to do it from the hydraulic systemProject M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
At first your not gonna get much but you have to pump the hell out of it. If your quick half an hour will do if not your gonna be there\ for quite a while. And follow the DIY posted.
Hydrolic clutch bleeding
This is just for your information. Feel free to do it like the book states.
When I replaced my master cylinder I had a hell of a time bleeding it.
(1) The first thing to remember is that sometimes it isn't your fault. I spend over a week trying to bleed my "new" master cylinder before getting pissed and putting the old one back on. Turns out the new one was defective and could not hold any pressure... It took me 10 seconds to bleed the "old one"
(2) Do not go buy a suction bleeder for brake lines (if you have one go ahead and try it) the reason i say this is because many aftermarket (and possibly OEM) Honda master cylinders have a floating hydraulic piston in them. What this means is that the little piston in it is not actually connected to the rod attached to the clutch pedal and when negative pressure is applied it sucks in and closes the valve preventing you from properly bleeding the system.
(3) The way I did it in 10 seconds was to buy a "suction gun" from an automotive store (costs like $15.00). It is basically a grease gun designed for liquids. Fill it up with brake fluid and with a couple feet of plastic tube attached to the end then turn it upside down and apply pressure till all the air is out and you are left with nothing but brake fluid. Apply the end of the plastic tubing to the nipple on the slave cylinder. Open the master cylinder reservoir and have a syringe or something handy to suck out the extra fluid. Make sure the clutch pedal is out (close to the chair). Open the bleeder valve on the slave cylinder (nipple the plastic is attached to) and apply pressure to the handle on the suction gun. Do this for a few moments removing fluid from the reservoir to prevent it from overflowing then have you or a friend close the bleeder valve (nipple) and feel the clutch. If it needs more pressure repeat. I did this for about 10 seconds then drove her around the block. Haven't had an issue in over 6 months.
Here is a picture of where the slave cylinder is and the bleeder valve (sorry if it is too big)
[IMG][/IMG]
If anyone has anything to add let me know, and if you have anymore questions feel free to ask.
thanks everyone! i was gettin frustrated because the pedal would go str8 to the floor and stay there. i'll try Ghetto_CB7 way first thing tomorrow morning because i know someone that has that item to bleed it. if not then i'll keep trying.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
Oh yea if you didnt bench bleed the MC your just gonna be there all day also.
that was the first thing i started doin once i installed it, very little fluid came out.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
Originally posted by NAiL05Oh yea if you didnt bench bleed the MC your just gonna be there all day also.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
Dump brake fluid into the MC and push the pushrod until you see fluid come out of the ports.
i dont have a grease gun, i have some kind of sunction gun. a lot of bubbles coming out when using it.
but what Ghetto_CB7 is saying is that with the grease gun filled up with fluid, im just applying fluid into the nipple instead of taken the air out? and if soo, i use all the fluid in the gun?Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
Bleeding
This does remove bubbles out of the system. Basically you are reverse pressure bleeding the system. I do not think I have a picture of the "suction gun" I used but i can run to an automotive store real quick and take a picture if you want. The bubbles should be coming out at the MC reservoir, and you should be applying positive pressure to the slave cylinder nipple. Make sure all the things I listed in my first post are done, and you should see a considerable increase in pressure within a few seconds. (It may be difficult to apply the pressure I used a piece of angle iron to help me get leverage. And yes the suction gun should be filled with brake fluid.
If you are still having difficulties list the steps you are taking to bleed it and we can fill in the gaps or let you know what to do differently. We will have you driving again in no time.
I never heard ofo the reverse bleed method you mention. You can get a one man bleeder. Basically caps over the cmc reservoir and just forces it out. Makes bleeding a one man job. And since your doing MC its gonna take a while to bleed. At first you will prob see nothing becuase you have to let the fluid travel through the lines. That takes a while and quite a bit of pumping.
