waht is the name of that part?
    i have heard people talk about it on this forum but i don't know what it is called. my idle jumps from 800-1600 rpm and i need to replace the part but i don't know what it is called. if somebody can help me that would be great.i htink it is a IACV but i don't know.
    www.rms-usa.com
    theres the idle air control valve,tps sensor,and iab sensor or last but not least your vacuum lines that can do that . Or you can be like me change all of these things time and time again come to find out it was my ecu thanks steve from hmotorsonline.
      i have replaced everything but the idle air control valve. i called honda and they want $170 for the thing. why so expensive?
      www.rms-usa.com
        go to junkyard never the stealership where the little evil hondaman awaits .
          I've got a used IAC for $20 shipped =)
          hold on to your butts
            is the IACV on the intake manifold? i have the f22b1 in my car and i believe it is on the upper back part of the manifold can anyone correct me?
            www.rms-usa.com
              IAC is on the manifold, and has a coolant line going in and out, plus 2 wires. It should have a DENSO sticker on it.
              The fast idle thermo valve just has coolant lines.
              The starting air valve only has a vaccuum line.
              (I think...)
                yup
                  I did one where the filter screen was gunked up. I pulled it off the car, doused it in carbeurator cleaner, shook it round to force out the gunk, let it dry, put it back on, and it ran like a champ!
                    Yeah i did the same thing when my car ran like crap I took it off used a little water brush with soap and had it back to nice and silver cause it was pitchblack. Then after that the idling thing went away slowly then stopped.
