I have a feeling my coil is failing, but I don't have another one to compare it to, or replace it with. I don't want to spend the money on a new one unless I know it needs to be replaced.
The car has trouble starting and running when its cold and/or when its humid out, which in FL is very often.
My Helms gives me instructions to test it, but the results to me are inconclusive. It would be of great help if someone else could grab a multimeter and give me the readings from their coil.
I just took readings from the coil cold, and its wet outside
My readings were
A-C = 1.4 ohms
A-S = 19.33k ohms
B-D = no reading
A-B = 5.6 and slowly dropping
I appreciate any help I can get!
My readings were
A-C = 1.4 ohms
A-S = 19.33k ohms
B-D = no reading
